how to calculated the resistance required to limit the current of a fan
kbtan
Member level 2
how to calculated the resistance required to limit the current of a fan connected 2 a 8051 microcontroller
Here is a part of the diagram
Note: Calculate R as to limit the current
For a 12V fan, R= 0. :-D
---------- Post added at 17:23 ---------- Previous post was at 17:18 ----------
If the fan rated voltage is different, we need to know the power consumption,
Ifan=P/Ufan
R= (12V – Ufan)/Ifan
Also need to insert a series resistor from the output of microcontroller to the base of transistor, so no need the resistor pull-up to the +5V.
Reactions: kbtan
    kbtan
I might be wrong but if the 12volts source is stable and always 12volts using a voltage regulator AND the fan works at 12volts does it need a limiting resistor??
If you power a 3volts led with constant stable 3 volts supply do you need a resistor to limit it? Apparently NO!
Reactions: kbtan
    kbtan
excuse me,mister_rf can u tell me that what is Ufan
Ufan= UDC fan :grin:
Reactions: kbtan
    kbtan
thanks this help me very much
