How to calculate dropping resistor?
smeezekitty
Junior Member level 3
Washington, USA
Say i have something that takes 9V @ 1ampere dc fed from a 12v regulated source.
What resistor / calculation to use to get the correct ohms in series to make the voltage within 9v +/- 1v.
(12V-9V) / 1A => 3Ω
Resistor's power rating:
Theoretical: P=RI² => 3W
In practice double this at least two times .. => ≥6W
IanP
You can try a dc-dc converter LM2575
Voltage dividing is ok if you are sure that the load is 9V 1A
will remain constant.
Best Regards,
Siong Boon
