amartin32
I want to build a analog to fiber optic link and am currently looking into using parallel ADC's with Serial outputs and then sending the serial information to a serial to fiber optic link.
Being a newbie, I do not quite understand how to calculate the amount of bandwidth I need for my system to work. I would like to transmit 4 analog signals with a sampling rate of 250 kHz and a 12 bit resolution.
Then the bit rate is 12 Mbps? (Sampling Rate needed in Hz*12 bits*# of Channels= bits per second)
From my understanding the bit rate calculated for the ADC must be 12 Msps?
I am also confused as what definition and calculation of bandwidth I should use in the context of this system?
Would this Evaluation board be used for I would like to do?
Link: **broken link removed**
I know that the Serial information is sent in the form of zeros and ones but there is no carrier frequency in serial transportation therefore I do not understand where bandwidth would come to play. Also does trouble shooting a serial transmission involve using an eye diagram?
I greatly appreciate any help.
