How to calc Efficiency Of Boost Converter n its relatations
mengghee
Full Member level 3
United Kingdom
Hi, I am currently designing a boost topology with a feedforward control, i am just wondering if anybody knows how i can calculate the efficiency and also how do i estimate the loss in the mosfet or what affects the efficiency. thank you very much
huojinsi
Full Member level 5
Re: How to calc Efficiency Of Boost Converter n its relatati
The efficiency η=Po/Pin=Po/(Po+Ploss).Ploss is very complex,and it is relation with the Rds,D,f,Io,etc,and Ploss includes conduction losses,switch losses. i also know very little!
    mengghee
scottieman
Full Member level 2
On Top of Silicon
Sorry that I am not helping you here.
Still I am curious to know how feedforward control can be done in boost converter?
If it is not related to any IP issue, do you mind sharing it with us here?
Thanks
Scottie
mengghee
Full Member level 3
United Kingdom
I am implementing it by taking the line input, feed it to a potential divider, and the potential divider is compared with a sawtooth waveform determining the pulse width.
rockycheng
Member level 5
Are you testing the real chip, or doing simulation in EDA? If it's EDA, there is a simple method. You can use a voltage source as the input voltage, so you know Vin (or Vg). And it is possible to get the rms value in steady state of output voltage (Vo), load current (Io), and the current flowing out of the voltage source (Iin). So you can calculate the efficiency η = (Vo*Io)/(Vin*Iin).
I think this way is theoretically correct.
mengghee
Full Member level 3
United Kingdom
what do you mean EDA ? and yes i can get the input voltage in simulation. i am going to simulate it and build it soon ... but i don't understand the rms part .. what should i get ? i am a newbie .... sorry and thank you very much ...
mengghee
Full Member level 3
United Kingdom
But I don't know how to simulate it using cadence, I am using PSpice to simulate it. I am just wondering if there is a formula or if you do have some links about it. thank you .
rockycheng
Member level 5
mengghee,
I'm not familiar with PSpice. But I think you can use this method. There should be some corresponding commands in PSpice to implement.
mengghee
Full Member level 3
United Kingdom
But I thought In a DC circuit. we shouldn't be bothered to much about RMS values... isn't that true ? thank you
zenisle
Full Member level 2
I suggest you try some common stracutre
mengghee
Full Member level 3
United Kingdom
what do you mean by common structure ? thank you
rockycheng
Member level 5
Actually the output voltage and current are not DC value. They have ripples. But I think you can also get a roughly correct result, if you just use their required value instead. As to the total current through the voltage source, you should use the average value, because it changes dynamically.
    mengghee
huojinsi
Full Member level 5
Hi mengghee:
If u are doing a simulation, no matter using pspice or cadence tool,the output voltage or current wave should be as the shape of picture, it has ripple wave and is not true DC voltage. At the steady-state, the out voltage or current wave look as if a sine wave, so u manualy calculate their averge value Io(av) respectively, the Po=Vo(av)*Io(av). Because the Vin and Iin is very easily obtained at the steady- state, u can calculate η=Po/Pin=Vo(av)*Io(av)/(Vin*Iin).
Hope it hepl u!
Reactions: Eshal
    mengghee
    Eshal
mengghee
Full Member level 3
United Kingdom
Thank you Huojinsi, but i am just wondering how we should obtain the average value ? should it be calculated like V(av)= (Vmax-Vmin)/2 ?? sorry a bit dumb. and do you know anything about the power loss ? like switching loss, conduction loss etc. thank you very much
huojinsi
Full Member level 5
1. About average value, u can calculate it according to Vmax and Vmin of steady-state sine,V(av)=Vmin+(Vmax-Vmin)/2=(Vmax+Vmin)/2. ur formula V(av)= (Vmax-Vmin)/2 is a peak to peak value,and it doesn't include DC voltage value. Actually,this is a single estimate method,but it can estimate ur efficiency.
2. About the calculate of power losses, it is very complex and i also know quite little! Generally, for the calculate of efficiency, basically use the single formula η=Po/Pin=Vo*Io/(Vin*Iin).
Hope it help u. Pls correct me if i am wrong!
    mengghee
edwintsu
Member level 4
China
1:`Calc efficiency. Do tran sweep by changing current load(using step-function signal), and then measure steady state v(rms), i(vin).
η=Po/Pin=v(rms)×i(load)/(v(vin)×i(vin))
2:`Power loss Reference.
B. Arbetter, R. Erickson and D. Maksimovic, “DC-DC Converter Design for Battery-Operated Systems,” 26th Annual IEEE Power Electronics Specialists Conference, Vol 1, 1995, pp.103–109.
J. Stratakos, “High-efficiency Low-Voltage DC-DC Conversion for Portable Applications,” UCB,Ph.D.Thesis,1998.
Hope it help u!
    mengghee
sumitj
Newbie level 6
Bangalore India
hi
to know mathematical analysis of calculating efficiency you can refer to paper titled
" A comprehensive power analysis and a highly efficient, mode-hopping dc-dc converter"
In this paper one section explains power analysis of dc-dc converters
powerguy
Newbie level 2
india
i am working on dc-dc converters and want to simulate on spice or cadence.
can you please tell me which library is used in spice.and which version of spice is used.
sw0ws1
Junior Member level 1
Hope it help u!
PLease i dont understand how to use step function to change current load??and can this be done by changing Rload??
anthor qes: when i press (print )in cadence calculator,it ask me to enter a value to print at .so which value it wants??
thanks in advance
