Hi friend,
First of all,
Open MPLAB IDE.
then go to project Menu ==> Project Wizard.
then click "Next" button ==> Select Microcontroller ==> Select compiler tool-suite(for ex. MPLAB C18 C Compiler(mcc18.exe)v3.34) ==> Create project location ==> Next ==> Finish.
then add C file in source file in workspace.
Then build it from Project Menu ==> Build all.
it will create hex file in same folder(project folder)
Hope this is help you.
Shyam
INDIA.
If u r using PIC MC..... try PICProgrammer..... easy to download.... easy to use.....
Hi friend,
First confirm that, you should properly install Compiler.
Because, MPLAB is only IDE(Integrated development environment ) Not compiler.
You must install Compiler like MPLAB-C18-Student-Edition-doc-v3_00-win32.
It is download freely from Microchip website.
Then Try this option,
Go to Project Menu ==> Build Options... ==> Project.
It will open one window,
In Directories tab, Give proper path for all directory
For ex.
Show directories for: Linker-Script Search path
gives ==> C:\MCC18\bin\mcc18.exe
Good luck.
Shyam.
Error 18 "HIDtest.c" Line 25(10,23): File can not be opened
Not in "C:\Program Files\PICC\devices\PIC18F458.h"
Hi vikky,
For this error, give proper directory path of include file.
which is done by this way,
Show directories for: Include Search path
give your header file path in box of window.
for ex.
gives ==> C:\MCC18\h
For configuration bit
Go to Help Menu ==> Topics.... ==> PIC18 Config setting ==> select your Microcontroller
It give you proper description of configuration bit and how it is set.
Good luck.
Shyam.
