How to burn codes into AT89C2051 microcontroller?
sri vignesh
Newbie level 1
hii .. plz tell me how to burn codings into at89c2051?.. i have got avr developmment board and avr dude . will it work? and for compiling the code keel / win wvr is appropriate . if some other s better, pls suggest..
Re: 8051 microcontroller
You need some tools for 8051
1 Compilers and assembler and IDE : SDCC-free, assembler-free, M-IDE - Free
2 Programmer for Atmel 8051 chips **broken link removed** if you can make one or you can buy from hear
3 you can use keil free version which has 2K limit.
AVR and 8051 are different so you can not use tools for both.
---------- Post added at 17:11 ---------- Previous post was at 15:41 ----------
sri vignesh said:
sir can you please assist me in burning the code. what are the steps i should follow. i have my code ready . and i have downloaded sdcc compiler, ASEM-51 .. what is KEEL software basically?
have you compiled your code? is it written in C or assembly ? first write your program using note pad or IDE then compile your code which will generate .hex file. if you are using SDCC it will create .ihex file you have to pack it to create .hex file see the manual of SDCC. then using programmer you have to burn the code in to chip. which programmer you are using?
Keil is a IDE with compiler, assembler inbuilt. but its not free. 2k limit.
Please Post all your query in threads, it will help others. Privet messages not going to help others.
A very easy to build and use ISP programmer is explained at the following link. Many have appreciated it and I am using it on regular basis without any problem. It is not expensive too and support many more devices.
@ark5230
That programmer is using parallel port. which is not available now a days, even some desktop motherboard does not have these.
but I have provided a link which uses serial port and can be used with usb to serial converter.
