Aug 30, 2007 #1 D drabos Full Member level 6 Joined Jan 3, 2006 Messages 397 Helped 45 Reputation 90 Reaction score 15 Trophy points 1,298 Activity points 3,768 I have transistor models in lib files for ADS. (BSIM 3.3 etc.. ) How can I use them? How can I build a basic design kit from them? Thanks,
Aug 30, 2007 #2 khouly Advanced Member level 5 Joined Oct 20, 2003 Messages 2,350 Helped 461 Reputation 916 Reaction score 101 Trophy points 1,343 Location EGYPT Activity points 13,242 ADS help need use netlist include , block to include the model but be sure that this model is compatible with ADS khouly
Aug 30, 2007 #3 memarian Full Member level 5 Joined Aug 11, 2004 Messages 256 Helped 57 Reputation 114 Reaction score 34 Trophy points 1,308 Activity points 2,008 Re: ADS help need Hi, If you have a full design kit, you can use Design Kit Menu(in ADS Main Page) and install design kit function, but you must be sure that your design kit file structure and model files are fully compatible with ADS. Good Luck!
Aug 30, 2007 #4 khouly Advanced Member level 5 Joined Oct 20, 2003 Messages 2,350 Helped 461 Reputation 916 Reaction score 101 Trophy points 1,343 Location EGYPT Activity points 13,242 ADS help need he want to build a design kit , he need to check the documentation on how to build it , it is not an easy thing khouly
Aug 31, 2007 #5 N nazanin Full Member level 4 Joined Mar 5, 2007 Messages 226 Helped 65 Reputation 138 Reaction score 21 Trophy points 1,298 Location iran Activity points 2,529 Re: ADS help need this link is toturial ADS: **broken link removed**
Sep 1, 2007 #6 Sadegh.j Advanced Member level 3 Joined Nov 29, 2006 Messages 749 Helped 48 Reputation 98 Reaction score 15 Trophy points 1,298 Activity points 5,585 Re: ADS help need hey Check the photo attached, the circuit does not necessarily work, I just made it to show you how to define a transistor using the BSIM model. Something else, check the circle that I have shown you. Cheers
Sep 1, 2007 #7 D drabos Full Member level 6 Joined Jan 3, 2006 Messages 397 Helped 45 Reputation 90 Reaction score 15 Trophy points 1,298 Activity points 3,768 ADS help need Thanks Sadegh But I want to use my file, so I look for the solution without typing all the parameters, just join the file to the transistor or something like that...
Sep 2, 2007 #8 Sadegh.j Advanced Member level 3 Joined Nov 29, 2006 Messages 749 Helped 48 Reputation 98 Reaction score 15 Trophy points 1,298 Activity points 5,585 Re: ADS help need Hey Got it, sorry about the miss understanding. Then check this one; (Never mind the circuit, does necessarily work, sorry about it) Obviously you have to put the library file in the right path. I will attach a second picture. Let me know if you have any other problems. Cheers
