how to build an inductor????
ironjaycuttler
Member level 2
Member level 2
México
how build a inductor????
I want a build a inductor for high frequency and i don't have a measuring device only i have a multimeter i can build a circuit where i can see how is the measure of one inductor in high frequency, somebody have a circuit??? :?
S
sick_man
Newbie level 1
grid dip oscilator
You need a GDO drid dip oscilator
it is a beet freq device that tunes a known inductor for a range of freq across a meter scale
giveing indication of the resonant freq of the circuit
note
becouse of the nature of inductors several peeks may be found
so the stongest dip in the meter is the higher Q factor of the coil coils or tanks parallel / series tank circuit your tuning up
a tip for hf dc - 30 mhz is use solid think copper
for vhf >30mhz thin silver and above thin solid silver
use pens and drills as formers {the non fluted end and wind a turn of tape round if you use enamaled wire }
this is quite precise from a known drill diameter
i trust this helps
a GDO can be made {look on the net for GRID DIP OSCILATOR}
or i bought one for 80 euro made by altai {i replaced there crumby poly cap with a nice silver cap the same value and calibrated it with a known coil from the set {you get five six or ten with it and each coil can calibrate the next scale } some are better than others
and valves work better than fets for this im convinced ages ago ./././ i also have an AVO gdo this is my treasured one as it rare to find and very expensive 200 - 300 euro ...
ironjaycuttler
Member level 2
Member level 2
México
Thanks!!
U help me friend, now i have some idea where i can start thanks!!! 8O
coppervaporlaser
Member level 3
Member level 3
if you're going to build air coils, use the wheeler formular for calculation...
bingoboy
Junior Member level 3
Or this.
Regards
ironjaycuttler
Member level 2
Member level 2
México
gracias!!!
Well i think this will help me very much with my project!!!! thanks everybody!!!!!!!!! 8O
filterman
Member level 2
Member level 2
Re: gracias!!!
Try this one too, very good for small cils ,high frequency,includes parasitics. Written by ALKEngineering(www.alkeng.com)
