How to build a simple white noise generator ?
ZengLei
Full Member level 1
WuHan China PR
diode noise generator
i want to build a simple one ,so i can understand the white noise thoroughly.
any suggestions or circuitry?
thanks
zener noise generator
every circuit is noisy, isnt it?
so u can have it
Hey u can have a pn sequence generator and its output will be a white noise genertor depending on ur bandwidth of interest u can use it.
another is in dds, we get a signal and lots of spur, elliminate this main signal, and amplify rest
build white noise generator
en~~~
i see many circuitry use the zener diode as the white noise source~~~~~
PN generator is a usual method, National previously had a MOS IC with PN generator to generate white noise for audio applications. Another usual method is by amplifying the voltage of a zener diode, it is band limited due to Cd || Rd time constant, but sufficient white for audio band. I don't have my old design folder at hand, thus I can't give you a circuit with component dimensions.
white noise zener
Yes, from part count aspect, a 8 pin micro is actually unrivaled. The point is that I didn't design a noise generator since 25 years...
B.T.W.: Zener diode noise isn't thermal noise, it's shot noise amplified by avalanche effect.
white noise generator ic
I got one as below:
how to make a white noise generator
A Psedue Noise genarator in one of the simplest ways.
