How to Build a 1 GHz Scope Probe for Next to Nothing
hot_chmock
Full Member level 2
Full Member level 2
Where it is nice
make oscilloscope probe
Instructions
Oscilloscope bandwidth is expensive, don't reduce it further with a slow probe. Expensive fast scope probes have high input impedance, which we do not need when looking at digital IC outputs. Oscilloscopes have more gain than we need for digital signals. So, let's sacrifice input impedance and voltage sensitivity, and save money.
Take a 3-ft piece of RG174 50-Ohm coax cable with a 50-ohm terminating BNC connector on one end, attach a 950 ohm (or 1 kilo ohm) small resistor to the other end and use a very short ground connection. Keep the ground-loop shorter than 0.5 inch.
Rise Time Budget
Ground loop (half-inch diameter) 0.17 ns
3-ft coax 0.05 Ns
BNC connector with 50 Ohm termination 0.01 Ns
Total rise time of 0.2 Ns means a bandwidth of 2 GHz. Input impedance 1 kilo ohm, input capacitance < 2 pF, attenuation 20:1.
hc
:wink:
S
sick_man
Newbie level 1
1 ghz scope
realy lets be honest
we only buy scope probes so you get the accesories like
gnd crock clip insulated probes ... probe clip s ....
three adapters incase you loose bits and spare tips {various types for different jobs}
i pay out about 15 - 25 £ sterling per year
and have done for 15 years
thats lots of bootle....
but a good comprimise
becouse i
1} dont get a dangerious probe }
2} if for instance i measure the wrong point with a coax probe say 200 watt rf coil instead of 13.8 v supply rail
im in deeep shit with coax with a resistor becouse i just damaged the front end amps pumping 200 watts in o dear 200w at 10.1 attenuator {probe coupled} = about 2 watts so down the lossy road = lots less damage and no toasted expensive front end opamps
3} its ok having 2 g bandwidth if you have a 4 - 10 gb scope haha
last one i saw cost as much as a lotus espree {and made you tea on demand and had a 1 billion year no quibble warenty}
4} bandwidth is irrelivent if the 3 db point of the scope dosnt exceed 20 mhz {as per every scope i have ever seen used or own}
so no matter what freq above 20 mhz you look at the carrier of
you always get flat gain tailing of 20 mhz before the muf or double the max freq range of the amplifiers in the front end of the scope
but man something tells me this is a good idea
becouse its cheeper
but a bad idea becouse it is dangerious and not realy needed
a decent probe does exactly as it descibes its self
or buy one that does exacly what you want
i use many probes some made from pens for prescalling my counter and a sliding pot for attenuation
so ... coax is good for me up to 200 mhz
coax is a strange substance
but what i will add is this
any piece of coax has its own resonants so it isnt a good idea
to measure for instance 3 ft wavelengh = 1 meter ~ 300 mhz
so 600 mhz is also a resanant lengh and 1.2 ghz etc
as for the resistor if you cut the legs to 1 mm and body together
will resonate near telephone freq ranges anything from 1 to 10 ghz
this can be a real problem
rf genius spend 10 years designing probes
the point with a probe is it dosnt resonate ....
so carriers {digital or analogue } dont destort as flux of various remixed freq coherse and transverse the workbench.....
a much better solution is to use a data sample and hold
and built the front end into a probe that then eliminates the problem
and allows for scaling to be done in the probe
a tight scallar scalling design
means a 20 mhz lab scope can be as powerfull as a 2 - 20 ghz bandwidth morgage scope
and to the flaw in your thinking of 50 ohms
in idea for the probe above
any ANY and EVERY scope
uses a 75 ohm adapter {although a 50 ohm one will fit {the center pin is a little bigger diameter so the 75 ohm panel socket on your scope gets brocken nice 1 eh ???}
so your 50 ohm one will off by .75 - 1 ratio in impedance at the point of the plug and all the way down the coax
so square waves at 100 mhz will be scewed and destorted
USE 75 OHM coax and plugs
i use this method
a 75 ohm terminator and a three way 75 ohm splitter
i can then plug in a "dummy load" for very strong signals
bleading most via the load
echo47
Advanced Member level 6
USA
make your own oscilloscope probe
Yes hot_chmock, excellent suggestion! For many years I have used similar probes with my 500 MHz scope.
I make x100 probes using a carefully shielded 4.99k RN55 resistor at the end of one meter of RG-174. I set my scope input to 50 ohms. For digital troubleshooting, these babies are far superior to my standard Tek P6139A probes. The capacitance is so low that sometimes I don't even need a ground clip!
hot_chmock
Full Member level 2
Full Member level 2
Where it is nice
build oscilloscope probe
Simbox,
I have a 500MHz scope but only 250Mhz probes, those things are very expansive.
When I mesure digital signals and want the best mesurement possible my scope provide (500 pico second time base) then there is no risk to put my probe on any other point that the one I really want.
For all other mesurements I use my standard probes.
hc
:wink:
S
sick_man
Newbie level 1
scope probe coax
THE NOTE I PUT WASNT MENT TO DETER PEOPLE FROM MAKING A PROBE
LIKE ABOVE
IT WAS MEARLY TO POINT OUT THAT IT IS STILL A DANGERIOUS WAY TO USE A PIECE OF COAX
AND A GOOD POINT IS
A MAN WHO CAN AFFORD A 500 MHZ SCOPE CAN AFFORD A PROBE
DO YOU DRIVE ??? IF SO I THINK YOU MUST BE A FLINTSTONE....
hot_chmock
Full Member level 2
Full Member level 2
Where it is nice
how to make your own oscilloscope probe
Simbox,
I bough this scope second hand, 2 year old, almost not used with not a scratch and perfect calibration for a fraction of the price.
No probes where supplyed with the scope.
Now I'm a flinstone that can watch with my scope up to 500 Mhz the heart beat from a my dynosore when I push him to pull my car up to 200 km/h!
hc
:wink:
S
sick_man
Newbie level 1
50 ohm oscilloscope probe
lol....
but he still needs a probe to get him moving and you must be expert by now
House_Cat
USA
measure ghz with mhz scope
There is a web page that talks about do-it-yourself projects for signal integrity measurements. One of the projects is a 1Ghz probe.
The web page is: h**p://emcesd.com/1ghzprob.htm
A copy of the probe construction project in PDF format is attached.
If you go to his home page, there are other low budget projects that are very useful.
JNovak
Junior Member level 1
build oscilloscope probes
Well, it may be a good idea with a coax and stuff. However, a probe that simple going to 2 GHz that's really suspicious. And by the way, if you are doing measurements with this kind of bandwidth, then you must be doing something serious and paid, why save on the commercial calibrated probes?
