slaskar
Newbie level 6
Can anybody help me to blink four LEDs connected to port A (RA0;RA1;RA2;RA3) with an interval of 2 seconds please explain the configuration bits and the control registers to do the job
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 void delay2s(void); //*************************************************************** void main(void) { TRISA=0x00; // Outputs PortA OSCCON=0x76; //Configure internal oscillator while(1) // endless loop { LATA=0x0F // Switch on four LEDs delay2s(); // Delay for 2s LATA=~LATA //Switch off LEDs (toggle port) delay2s(); // Delay for 2s } }//end main //*************************************************************** *************************************************************** void delay2s(void){ int count; for (count = 0; count < 40; count++) { __delay_ms(50); } }//end delay2s
You can calculate your delay as per your requirement and according to your crystal frequency..
Go here,
and for blinking an led go to microchip tutorials for general i/o programming.
Go here,
can anybody tell me the location of ADCON register in PIC 16F628A
IN PIC16F628A PORT A is associated with CMCON (LOCATION : 1Fh) ; VRCON (LOCATION : 9Fh) but i donn't think ADCON register is there in PIC16F628A
#INCLUDE <P16F628A.INC>
#DEFINE BANK0 BCF STATUS,RP0
#DEFINE BANK1 BSF STATUS,RP0
__CONFIG _HS_OSC & _WDTE_OFF & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _BOREN_OFF & _LVP_OFF & _CPD_OFF & DATA_CP_OFF & _CP_OFF
ERRORLEVEL -302
CBLOCK 0x20
TEMP1
TEMP2
TEMP3
ENDC
ORG 0X00
GOTO INICIO
ORG 0X04
INTSAI
NOP
RETFIE
INICIO
BANK0
CLRF PORTA
CLRF PORTB
MOVLW 0X07
MOVWF CMCON
BANK1
MOVLW B'00000000'
MOVWF TRISA
MOVLW B'00000000'
MOVWF TRISB
MOVLW B'10000000'
MOVWF OPTION_REG
BANK0
MOVLW 0
MOVWF PORTA
MOVWF PORTB
MAIN
BCF PORTA,3 ; this is pin 2 on IC (RA3) (Logical Level 0)
CALL DELAY2S
BSF PORTA,3 ;(Logical Level 1)
CALL DELAY2S
GOTO MAIN
; Delay = 2 seconds
; Clock frequency = 20 MHz
; Actual delay = 2 seconds = 10000000 cycles
; Error = 0 %
DELAY2S
;9999995 CYCLES
MOVLW 0X5A
MOVWF TEMP1
MOVLW 0XCD
MOVWF TEMP2
MOVLW 0X16
MOVWF TEMP3
LOOP_DELAY
DECFSZ TEMP1, F
GOTO $+2
DECFSZ TEMP2, F
GOTO $+2
DECFSZ TEMP3, F
GOTO LOOP_DELAY
;1 CYCLE
NOP
;4 CYCLES (INCLUDING CALL)
RETURN
END
