How to begin DSP work?
UroBoros
Advanced Member level 2
Cochin - India
Hi
I have MATLAB with me,A few books about MATLAB and DSP, and some Microchip DSPIC controller samples. and ICD2 to programe DSPIC.
I am reasonabily sound in MCU work,but new to DSP.
Any simple projects which I can start with the above mentioned resourses avaialable with me?
please guide
picstudent
DSP programming is far different from the programming of microcontroller. DSP is designed to perform the efficient mathematical operations. If you are working dsPIC i.e. 16 bit DSP then you should know the Q15 fixed point arithmetic.
To start with,
1. write the program to find the square root of a finite number.
2. Write down the program for moving average filter with m coeff. and n taps.
also try to implement the DSP algorithms in fixed point arithmetic. This will definitely give you flavor of DSP. One can use DSP exactly like high speed microcontroller. But I think in such a cases the power of DSP is not used efficiently.
The selection of DSP/MCU is depends upon the application need and programmer skill.
rest is same.
Enjoy
Nandu
    UroBoros
If you are working on dsPIC33 16-bits devices, you must visit my website www.sim2lab.com
Here you can find a good tool for developing embedded systems in Simulink for dsPIC chips. SIM2LAB dsPIC33 Target Blockset offers a cost effective solution for rapid-prototyping. You can also build your own GUI (Graphical User Interface) for data logging/monitoring, as well as change on-the-fly the software parameters.
Visit my website for further details and download your evaluation copy.
