How to avoid transients in a circuit?
kad
Junior Member level 2
Im working on a small project presently...which i could get it to some extent...but the problem is as soon as i switch on the powersupply i find some transients in the circuit ...can anyone suggest a way to avoid those transients...otherwise the circuit is working properly
Eric Best
Member level 4
Member level 4
Re: doubt
If you want anybody to help you, you must specify your problem more precisely...
Your description can be clear just for clairvoyants.
Eric
jeffttan
Member level 2
Member level 2
doubt
hi, you could at least provide us with a schematic.. and describe what is the purpose of your project.. thanks
wwfeda
Junior Member level 3
Re: doubt
It sounds like you need bypassing. For your power supply pins, tie 10uF capacitor at each of your power pins to ground. For your op-amps and device with power pins, tie 4.7uF and 0.1uF capacitors very close to the pins.
In the case you have really bad spikes coming from your supply, put 2 clamping diodes at the power supply pins. This would clamp your supplies from really nasty spike.
Eric Best
Member level 4
Member level 4
Re: doubt
Well, the first clairvoyant... ;-)
(don't take it bad, I'm joking)
Eric
