How to avoid or reduce noise?
Victory1981
Newbie level 6
Newbie level 6
Hi,everyone. I'm a newbie on circuit design. And I met some problems when I connected the digital circuit to the analog circuit. That's Noise! I have fought for noise for a week but the achievement was not as great as I expected. The digital noise affected the whole circuit greatly especially when the analog circuit had a low frequency(say, 500Hz or lower). Can some one come up with some rules for reducing noise from digital circuit?
What I already done:
1. connected 0.1uF between Vcc and Gnd for every IC.
2. analog circuit and digital circuit have seperated ground and are connected at one point.
flatulent
Advanced Member level 6
Middle Earth
slower logic family
One trick is to use a slower logic family in the digital area. Another is to run the digital on the lowest power supply voltage that will work.
Do you have separate power planes that are only under their respective circuit areas? Run separate ground and power lines from both sections back to the powe supply.
BigBoss
Türkiye
To reduce the noise for the mixed circuits some attentions should be paid..
- Very good seperated ground connections that are converged onto only one point which is power supply ground..
- Very clean noisless power supply
- Seperate VCC lines which are passed "feedthru" capacitors into concerned circuits
- On the VCC lines , some inductive low pass filters or SMD noise supressors( Murata , Epcos , Toko etc. ) must be placed
- For transient noises , for every digital circuit VCC, a small amount resistor and decoupling capacitors may be placed..
- If it's possible double sided PCB is much more better then should be screwed on the circuit housing with a cover copper clad
- High speed square waves create harmonics on either supply lines and signal lines , therefore shielding can be applicable and/or shielded cables mignt be used for signal lines and VCC lines if there isn't cost problem..
- Closed and magnetically isolated housings or boxes..
- And finally..PCB design must be very very carefully implemented
Noise problem is the one of the most difficult problem in electronics.. They should be very carefully analyzed and solutions must be applied regarding to rules and laws..
Regards
House_Cat
USA
The "separated grounds" are not a magical way to prevent coupling between ananlog and digital. The important issue is the complete loop formed by each signal.
You need to look carefully at the return path for each trace, and ensure that none of the analog return paths are coupled to the digital return paths. If you have run traces for the analog signals that have the digital plane directly below or above them, you may have the return current for that trace flowing in parallel with a digital return path on the so-called digital ground.
Moreover, if there is a signal that cannot return directly to the source via the lowest impedance path on the nearest plane, it will eventually have to go thru that single via that connects your two ground planes. That point will then allow modulation of the return path across the via inductive impedance (ie 'noise' will be coupled from all other similar returns trying to complete the loop through the via).
Again - every signal is a loop. There has to be a well defined return path for every signal source. Try to think in three dimensions, and follow every signal path from source through sink and back to source. If you can't make a smooth, uninterrupted loop that is clear of fast risetime signal sources, you will have noise.
falling_stone
Member level 1
Member level 1
How to avoid or reduce noise? - low frequency noise
Dear Victory1981,
Please take a look at the following topic, there are some explanations about capacitive decoupling:
If You suffer mostly from the low-frequency noise, the best way to suppress it - using active regulation circuitry. Lets say that Your analog part requires +5V power supply, then take something higher (...8-12V) and use additional linear voltage regulator to reduce it to +5V with good capacitive coupling, this may reduce low-frequency noise by ~30-40dB. However be VERY carefull and check if all ot the mixed signal devices (ADCs/DACs or others even having I2C control from digital part, for example) will not latch up if the power from digital side will arrive before the analog power (since it takes time for voltage regulator to charge all the capacitive load and stabilize). If latching up may happen, then use some digital power supply delaying technics (either disabling power supply itself or switching its output voltage) that will ensure simultaneous powering-up of both analog and digital parts.
Best Regards,
F.S.
gauiver
Member level 5
Member level 5
the noise is usually high frequency sigals before feeding your digital data to analog input use low pass filter filtering the high frequency data. also it depends upon the buffering capability of the digital ic's. the higher the buffering strength the higher the noise since a greater time is required to change speed. also try using high speed ic's. sometimes it is useful to vcc and gnd via capacitors to avoid noise due to fluctuation. the capacitor should be of high value.
