How to assign vectors to array in VHDL
xilinx1001
Member level 3
Member level 3
I need to give two 9 bit values(cm, cm2) to an array
cm and cm2 contains the two 9 bit values
I am doing something like this which is not working
TYPE matrix IS ARRAY (0 TO 2) OF STD_LOGIC_VECTOR(8 DOWNTO 0); --type definitions
SIGNAL x: matrix; --signal declarations
matrix(0)<= cm,
matrix(1)<=cm2
Can you suggest anything about this?
Regards
xilinx1001
That looks almost right, assuming cm and cm2 have been declared as std_logic_vector(8 downto 0). You need to terminate your assignment statements with ";", not ",".
What errors are you getting?
I am getting the errors like this
Line 246. The expression can not be converted to type matrix.
Line 247. The expression can not be converted to type matrix.
Actually I need to display the two 9 bit values continuously in a circular sequence
For thatI am actually thinking of some thing like this:
code:
begincountClock: process(CLK, count)
begin
if rising_edge(segclk) then
if count < "10000000" then--creating a delay of 0.02 seconds and 50 hertzs
a<=cm;
else
if count < "20000000" then
a<=cm2;
count<=(others=>'0');
end if;
end if;
end if;
end process;
1. The code you wrote dosen't create a delay at all. before you use the expression "count<10000000" you should make the count signal to increase with every clock edge.in other words you should make a clock counter.
2.it seems that the error is because of a type mismatch. please send line 246 and 247 of your code. by the way which libraries did you evoke at the beginning of the code?
