Thx Mr.ME do you have any PCB layout for simple starter board that support (AT90s,ATMega PDIP socket) and support with stk 200 but in single layout only?the Schematic that you gave to me is STK 200 right?Do you have stk 500 dongle schematic?Thx Mr.Me.
Here is a combined STK500 and JTAG dongle:
Evertool AVRISP/STK500-protocol and JTAGICE compatible Programmer/JTAG debugger. **broken link removed**
Very nice 2-in-1 tool.
The JTAG interface can also be very useful for In-Circuit Emulation (ICE) and can also be use for programming instead of AVRISP.
AVR ATmega16 and up, has JTAG interface.
You can just leave out the JTAGICE section in the beginning if you like and then mount it later.
This project is still in development, last update was made less than 14 days ago, but I think the version 0.7 that is already published will work fine.
I found it at page 3 in this topic posted by Twinsen:
You could also buy the original ATMEL AVRISP instead. ATMEL AVRISP uses the same protocol as STK500, in fact the same circuit is mounted at as the ISP part of the STK500 board.
It is not STK200 compatible, because it is for serial port. STK200 uses parallel port.
This is a SI-Prog compatible programmer.
Not to sound rude, but if you cared to read the links already posted you would know this! http://www.olimex.com/dev/avr-pg1b.html http://www.lancos.com/siprogsch.html
If you compare theses two schematics with the one you have uploaded, you can easily see that they have the same connections.
I doesn't hurt to do a little research before you ask questions.
Thx.MrME.Mr.ME.What about this schematic, it is working?it use serial connection.it is compatible stk 200?
I'm rather confused about jtag ICE. If i use atmega,should i use jtag ice?
What is jtag ice function?If i do hardware simulation, can i only use isp programmer only, without Jtag ice?In "evertool" there is ATMega 16 what is the function of this IC?What is the meaning of these"The JTAG ICE is a Real Time In-Circuit Emulator for megaAVR devices with JTAG interface"? 8O Thx.Mr.ME
I'M UNDER GRADUATE STUDENT
i'm doing my final year project using the microc. i hav a transmitter node n a recevr node. i hv tried to use USART, but it only can trnsmit 9 bit dat (max).
coz of i also use the TCP/IP protocol, so i hav 42 bytes data including thr TCP n IP header (20 bytes each). i measure the temperature using temp sensor at port c.
so i would like to knw maybe hav a method to transmit all of the data in a time..
