You'll need a properly designed mosFET/BJT class A/B amplifier driving hi voltage biMosfets in a full bridge configuration to your load, this allows a 1500 volt rail max and the bandwidth and rise times you require, a transformer step up will not give you the edges you require - Regards, Orson Cart.
