I wonder tthat how the clock latency influences the timing.
In my opinion, if clock latency is worse. Then all the arrival time of the clock will be delayed equally to the register clock pins. So which aspect will be worsen when
the clock latency is worse. Thank you very much!
note that clock skew has 2 components
- structural skew
- PVT skew
as you increase clock tree delay and balance it , structural skew is Okay,but
PVT skew becomes worst . i.e more buffers in clock path will have more
more variations in PVT (Process , Voltage , Temperature) and hence skew
increases.
some people call PVT skew as OCV (on chip variations)
clock latency matters in STA for sure but its effect is different from that of clock skew. li's answer that clock latency matters since it worsen the hold time. It is more like it. But for which flip-flops and under what conditions? Other effects of clock latency? when it is going to worse the setup time?
I put my two-cents in my blog. **broken link removed**
