How skew value and max insertion delays are calculated?
qual_ti
Member level 1
hi,
why skew should be minimal?
How skew value and max insertion delays are calculated which we can specify in the CTS specification file ?
ravipandu46338@gmail.com
Member level 2
INDIA
Re: clock skew and timing
Skew is the difference between the arrival times of clock to the clock pins of register
insertion delay:- The delay from clock definition point to clock pin of register
if skew is maximum then timing will not be met....,that is the reason why skew should be minimum
Thanks&Regards,
D.Raviteja
qual_ti
Member level 1
thanks for reply.
My question is we set these skew and insertion delay values in CTS specification file...
On what basis these two values decided ?
One more question ...
Which one is important either Global or local skew ? and why ?
Thanks&Regards,
D.Raviteja
dftrtl
Banned
Bangalore
We set these values depending on technology what we achieve.
Local Skew is important as it determines timing closure.
