I need to simulate an rs232 transmission and reception, with a 16f84a programmed into ccs. My problem is, how can I do to test rs-232 data and input (receive) rs232 data?.
Thanks in advance
You can do as dimmy said
or
try to learn how to use COMPIM for real RS232...
you can use null-modem cable to work with PC application also..
As i did before i made the AVR program for GPS display and connected to both GPS simulator and real GPS
Thanks in advance
Use the Virtual terminal. With Virtual terminal, you can print/type asci characters to be received or to be send. It's very usefull and easy to use. It is like to use a serial port with Hyper terminal.
