JackofallTrades
Newbie level 6
- Joined
- Mar 28, 2014
- Messages
- 11
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 103
Hello.
I have a system in which a PC switches on an off various loads .
Small resistive loads work fine, as do DC inductive loads with the proper flyback diode circuit.
For one large AC inductive load however (a small household box fan), I am getting system malfunctions presumably from AC switching noise. The AC fan is controlled through a contactor and the PC will periodically hang upon turning the fan off.
For the contactor the input coil has a flyback diode which is working correctly to limit voltage back to the PC. Therefore I presume the noise is the energy from the fans coil collapsing back into the AC line. To get a measure of the fans steady state current, I plugged a "Kill-a-Watt" inline with the switched output to the fan and the problem improved greatly. This also leads me to believing the lockup is caused by noise on the AC side of the system.
I do not have differential probes nor a battery operated scope to look at the AC line properly.
Is there a circuit, corresponding to the flyback diode, to sink current caused by the collapsing field for AC loads?
