how much the rate of read form a usb flash?
jason_bill
Junior Member level 2
Hi
I have a buffer (in microcontroller) and must read data from it at 112Mbits/s that this data saved in a memory.
now i want to understand that, can i use a usb flash as memory that this data stored on it and then read the data from it with speed rate more than 112Mbits/s and save in my buffer?
in wiki is mentioned that" higher maximum signaling rate of 480 Mbit/s (effective throughput up to 35 MB/s or 280 Mbit/s) (now called "Hi-Speed")".
Thanks.
Are you sending data to micro's buffer? If yes, does your micro really have that much memory to store atleast 112 MBits which come in 1 sec? You want to store data to some memory like SD card or USB flash?
You want to interface pen drive to micro?
thanks for reply
actually i didn't decide how to save and send data exactly, and of course, my intention about that i mention above is : micro receive data from a memory for example usb flash (because i think usb flash is just way that i receive data at 112 Mbits/s and more), and then write in a limited buffer and controlled such whether there is an empty entry to save a new data or there is an entry that rad and sent out its data.
yes, but also i have nand flash in minde, i must mention that i need a memory with at least 4 Gbyte capacity.
i don't want to use any external ram for buffering, and my micro, i think at least has 1 kbyte for buffering.
if your intention is "usb flash", yes, and just as a memory that store my data and then send them through a micro on SMA connector at 112Mbits/s.
thanks.
