How many times can I use "retlw" in a Assembly table?
newbie111
Member level 2
h.k
Table ADDWF PCL, f ;data table for bit pattern
to make a table in assembly
is the limit ff times?
Thanks
Re: assembly table
For example
	retlw	b'1001'
        retlw   b'0110'
       retlw  b'1001'
       retlw b'0110'
retlw	b'1001'
        retlw   b'0110'
       retlw  b'1001'
       retlw b'0110'
      retlw b'0001'
       retlw b'0010'
       retlw b'0100'
I just know to know how many times i can use "retlw" in a table.( I have used 11 times)
Thanks
Added after 33 seconds:
I just WANT to know*******
Re: assembly table
To simply answer your question, Yes, FF is the max table size.
For your current work there should be no problem creating small tables like that.
However when using large tables other things come into play and must be accounted for, but unfortunately lookup tables are not readily / clearly documented
If you go to this forum and search for 'tables' and look though some of the posts you will find some good info
https://www.microchip.com/forums/tt.aspx?forumid=11
It is a great site for good info and they readily help genuine questioners like yourself.
Also have a look at this manual which has some extra info not always detailed in the datasheets
https://ww1.microchip.com/downloads/en/devicedoc/33023a.pdf
If you do get chance to change from the 16F chips to the 18F range you will find virutally all these Banking, Paging , PCL problems that you so easily get with the 16Fs are a thing of the past - just that the 16F has been so popular with many examples out there , but people seem lost to the fact of how good the 18Fs are.
The assembler code is virtually the same but with a good few new instructions to make things even easier.
You can get the small 18F1320 or the 40pin 18F4520/4620 for much the same price as their 16F equivalents.
    newbie111
Re: assembly table
Do be careful where you place the table. If it spans a page boundary the page selection bits will not be updated so you will 'wrap' back to the beginning of the page where the table starts.
You can partially get around this by placing the table at the start of a page, for example:
org 0x200
mytable addwf PCL,w
but bear in mind that the 'addwf' instruction is also in the page so you have one less space to place data, it's maximum length becomes 0xFE.
As wp100 states, the 18F series uses a more linear addressing system so you do not have this limitation.
Brian.
    newbie111
Re: assembly table
Great answers from you two.
All clear!
