dinesh401
i am using at89s52 controller port as a output .. from that port i connected to a 8 bit buffer. from the output of buffer ic(74ls573) i want to connect 18 multiplexers(cd4051) ic's which is having the common bus line. is there any problem while connecting this type of circuit.
according to the datasheets, the output current of buffer is 20uA. and the input current of multiplexer is 0.1uA.
if i connect like this, will there any problem?
