amsdesign
Member level 3
Hello,
I have a negative feedback control system (a PLL)
The loop filter is a phase lead-lag filter. Can you tell me how such a filter can compensate for leading and lagging actions of the input signals ?
This is part of the text that says so, how exactly does does it compensate?
Here is the filter :
A note on terminology: a lead-lag[also called lag-lead] filter combines a phase-leading with a phase-lagging net-work. The phase-leading action comes from the numerator [in other words, from the zero] in the transfer function in Eq.(2.29a), whereas the denominator [that is, the pole] produces the phase lag. All filters used as loop filters are lead-lagfilters)
