How is it poss it possible to remove the [SOLVED] prefix from the thread's subject?
ivlsi
Advanced Member level 3
How is it possible to remove the [SOLVED] prefix from the thread's subject?
You should be able to select 'edit thread' at the top and there is the option then to add a prefix. [it may be under a different heading, or look under the 'edit thread']
Keith
Click 'Thread Tools', then 'mark this thread unsolved' . Only if it's your thread of course...
No, the thread is not mine, but I continue it...
does it may happen it was removed by itself without asking for that? but it exactly was happen...
---------- Post added at 00:01 ---------- Previous post was at 00:00 ----------
"I found your post What tool should be used to simulate a DFT design? I have set the thread to unsolved." - Thank you! You have read my mind :)
I think that rather than trying to "unsolve" a "solved" thread it would be better to start a new one!
Keith
