How important is the check_design command for synthesis?
After doing check_design I FIND THERE ARE SOME PROBLEMS IN MY DESIGN. The report generated after check_design contain name of some instances and also nets that are not present in the design file. I am using the check_design command before compilation. How to see these problems whose correponding instance and net name are not present in the RTL which ere analyzed and elaborated.
The warnings generated by check_design command are important and should be carefully analysed before u neglect them, if u r the designer for that particular block, u should be knowing the gate inference from that RTL code. Isn't it??
The code os too big to understand all the instances of it. Again the name of the instances reported by check_design command are not present as an instance in the complete design. We do not know the blocks which are inferred by those functions.
