how i configure my router with ethernet controller?!
asrock
Junior Member level 3
hello every one
now days , i made a project "Ethernet Controller" that uses 16f877 and ENC28J60
and it works successfully with direct connection with CrossOvr cable to my labtop
but i want to connect my project with enternet through router
can any one give me the global settings for router to set :
IP Address
default gateway
DNS server
and is there any other settings that i must set??
or there is a certain routers for that??
hope help me ;
my greetings :)
In case that you have dynamic public IP address then you set DDNS. This will allow you to connect to your web server from any location from Internet.
Web server is connected on router port, you need to do some port mapping for incoming HTTP protocol TCP80 requests, and to configure DDNS in router configuration.
Best regards,
Peter
:wink:
