How i can measure and view AC signal under 5 milliVolt
nima_1981
Member level 3
Member level 3
Ocean Mind
Hi
I have a RIGOL oscilloscope and i can view ac signal and measure that voltage by micro Controller (atmega32)
But when that signal become under 5 milli volt my oscilloscope can not show that signal and also i can not read that signal by Micro Controller , Please Help me to View and measure that signal .
Did You have any Deferential Micro Volt meter Schematic ??
amplifying is one solution, but if your signal is noisy then you also amplify the noise.
To get around this:
You my use analog filters (lpf, hpf) combined with the amplifierc to get rid of some noise.
If your frequency is known you can use mathematical solution in software like filters, correlation, dft to get reliable values of very small signals.
Hope this helps.
Klaus
Edit1: some spelling
what's purpose to measure that signal, to check time domain waveform or check else?
if that is for waveform, the low noise amplifier is the best way.
Hi guys
Thank you for reply only i want measure RMS that Signal . but i can not best solution's for that i use ad620 but that is not liner . did you have any solution for measure that signal ??
and that small signal you see it its deferential voltage across the resistor , this is milli ohm meter or micro ohm meter .
and about that noise i think that's only error of my oscilloscope .
You can use LT1028 as well, there is an example called "Low Noise, Wide Bandwidth Instrumentation Amplifier" in the data sheet. I guess this would work fine to measure a differential signal.
    V
Hi emmert
is that shematic ??
1) How i can change that gain (its 1000) and what is that formula ?
2) I can not find lt1208 in our country , can you say to me another part number that same as Lt1028
thank you
Lt1028, yes. I've used them, they are very low noise.
You say milliohm shunt, then you need an opamp with low voltage noise, usually with bipolar input stage.
(Not with fet input stage), A good layout design is also important when you amplify that small signals.
Lt1028 has about 0.85 nV / sqr(Hz) and a very low 1/f corner frequency.
There are many opamps with low voltage noise. TI, ST, AD....
Do you have access to distributors like farnell or digikey in your country?
Klaus
One more thing.
Maybe one side of your shunt is connected to gnd, then you can use a one opamp solution instead of the 3 opamp instrumentation amplifier.
Klaus
Hi nima_1981,
I suggest you to look up Linear Technology Design Note 355 called "Op Amp Selection Guide for Optimum Noise Performance", i think this document is very helpfull.
About the gain, I can not say the formula directly by looking up, most plausible solution is the testing the circuit in LTspice. (software is free of charge)
And what about formula of gain in that solution?
You want me to do your homework?
Look for "noninverting opamp circuit".
I'm sure you can solve it by your own,
and be proud of you.
Good luck
Klaus
please help me for design a industrial amplifier with op amp with 3 gain 1- 10 - 100
as i say i found this but i can not change gain i need 3 gain also i can not find how i can change tha gain of this structure .
thanks
It is an ordinary instrumentation amplifier that is shown in books, in school and in Google.
I found this one in Google where they tell you how to simply change the gain:
