i designed an array of patch antenna with coaxial fed, and defined it as wave port, but i need put it in a radiation box so i need defined is as lumped port , how i can do that ? i'm not perfect in hfss program can any body help me please ?
Usually what I do in such cases is integrate the lumped port into the ground plane. Subtract a hole out of the ground plane at your feed location, and put a circular sheet there which your lumped port is assigned to. Extend a conductor up through the dielectric to model the pin, and the outer edge of the port should be the ground plane.
