Hi Eirp,
1.5G? It must be quite a big structure! 8O What were your mesh settings? I noticed that CST uses a lot more mesh cells if you haven´t got a planar structure (such as a curved body of an aircraft) I had to use staircase mesh for the imported sheet body. Till now, I still haven´t got the hang of disabling automatic mesh and using maunal mesh. Do you have any advise for me on generating manual mesh apart from the example in the advance topic manual?
Referring to the agreement with measurements, what measurments are you actually to?
Cheers,
Element7k
eirp said:
Structure ~10x10 lambda was the hardest I ever simulated. It takes 6 millions of cells, 1.5 GB of RAM and weekend to finish :crazyeyes:
In fact, results are in very good agreement with measurements.
I think more suitable is to use GTD for large objects as does FEKO, FDTD has its natural limitations..
Rgz,
Eirp
