how does the data rate of a signal affects the traversal over a relay?
sachinkp21587
Member level 2
Member level 2
india (U.P.)
i am using a relay with part number RA4-12W-K. i want to use it to make a ethernet switch using this relay. i do not know upto how much speed it will support. can anybody please guide me what factors are to be considered for high data rate support like 400Mbps ? how will a relay be affecting the signal traversal if the data rate changes towards very high to very low.
when i just had a look into the datasheet it showed no parameter saying supported data rate or something.
Regards,
Sachin
Not quite right. The datasheet shows insertion loss and isolation for frequencies up to 50 MHz, (measured with 75 ohm transmision line impedance, apparently related to video applications).
In other words, the relay isn't intended for operation at 400 Mbps (200 MHz signal frequency). It may still work based on the ruggedness of the ethernet physical layer, but hardly comply with the signal quality specifications.
