How does a magnetic resolver work ?
kileen
Member level 1
Member level 1
India
How does a magnetic resolver (pattern based --like inductosyn) work ?
Any material / books -- regarding design aspects ?
kileen
human2003
Member level 3
Member level 3
angular resolver
kileen
just punch in encoders in servomotors in a search engine
flatulent
Advanced Member level 6
Middle Earth
resolver signal processing
This link talks about resolvers and the device you mention. www.ee.scu.edu/classes/2000spring/elen131/lecture2.ppt
In general there is a electro magnet that can rotate. Around the outside there are many pick up coils. They are wired in two series strings with the coils alternating around the circumfrence. By measuring the ratio of the signals picked up you can detect position of the rotating coil to a fraction of the distance between the two adjacent coils. The whole system is operated on an AC signal in the electromagnet.
By keeping track of the total rotation, the absolute angle of the rotating coil can be determined. If the system is zeroed at a know position the absolute rotation can be calculated.
This system is similar to optical encoders.
kileen
Member level 1
Member level 1
India
design of inductosyn on pcb
from the material that i could lay hands on they talk about interpolating to get higher resolution. I want to design one with pcb tracks. Is it possible ? Any ebooks / design ref etc would be helpful.
Thanks
kileen
flatulent
Middle Earth
zeroing absolute resolvers
The finding the ratio of adjacent pickups is the interpolation. This also is done in optical sensor devices.
You would probably be able to make a better rotation sensor with optical than magnetic devices if you are restricted to conductors on PC cards.
tschang06
Newbie level 3
Newbie level 3
how does resolver work
1 WARNING SENT
hobbymat
Member level 1
Member level 1
resolver how does it work
You might also want to do a search on LVDT (linear variable differential transformer) which is basically a resolver in a linear form. Its output is in DC form, although it's driven with AC. If you want any good resolution you'll need good low-noise amplifiers and AD converters, among many other things.
Perhaps the way to go would nowadays be to use either an absolute encoder with enough bits or an incremental encoder with enough lines, plus an index signal for accurate reference point calibration.
If you can't achieve enough resolution with an incremental encoder disc, you can probably place another sensor head adjacent to the existing one, plus some XOR logic to double the resolution. The placement of the second sensor head is critical, but it can be done.
One good manufacturer of absolute encoders is Stegmann.
Just my 2 euroCents,
Hobbie
flatulent
Middle Earth
how does resolver works
I have found a good book reference on the inductosyns. Analog-Digital Conversion Handbook (third edition) by Analog Devices IC company page 449.
The construction is on one surface a zig zag trace in the shape of the graph of a square wave. On the other surface that moves relative to the first surface is another identicla trace that is much shorter. This forms an air core transformer. As the two surfaces move the coupling changes from zero to plus to zero to minus and back to zero. If the square wave type trace has the zigs and zags closely spaced, several thousand can be put around a circle. There is also another pickup zig zag that is displaced from the fist one by a quarter of the zig zag period.
The Analog Devices signal processing claims to be able to resolve one period of movement into 2^12 parts giving seconds of arc resolution.
kileen
Member level 1
Member level 1
India
16 bit resolver resolution
the two different signals are out of phase by 90 degree.Thus a sin and cos signal is obtained and from this angular data is obtained. The book is last published in 1997. Is there an ebook version ?
kileen
G
Newbie level 1
resolver sensor.ppt
You can find the explanation on analog divices .They are producing resolver to digital converters 2S82 , 2S83 ,2S84 which can be used in 10,12,14,16 bit mode and thus can not be compared to encoders.* in resolution I mean 16 bit - 65535 impulses HI)
Greetings
Dragan
kileen
Member level 1
Member level 1
India
principle of resolver as a measuring device.ppt
i am looking for 19 bits of resolution
kileen
flatulent
Middle Earth
analog device 2s82
Contact the manufacturer of the inductosync or Analog Devices for suggestions.
kileen
Member level 1
Member level 1
India
resolvers 1997
induc*t* ----no answer
will try A-D
while searching found another mfrr---Netzer. Their product is based on capacitance.
kileen
