How do you excite a stripline?
vfurlan
Full Member level 2
Slovenia
Hi!
I have I very simple question (I think it's simple). How do you excite a stripline? With coax cable or? If with coax cable – how do you connect the cable to the stripline?
Thanks in advance!
Re: microstrip excitation
I think the best is to use a stripline to CPW transistion.
Here is an example:
Thanks but this will not work for my. Any other ideas?
Re: stripline excitation
Coax to stripline is the best possible transistion, since the Efields match up the best. You have to make sure there is a good ground connection between the top ground plane and the coax outer conductor, and a good ground connection between the bottom ground plane and the coax outer conductor.
    vfurlan
coax excitation is the best if the diameter of outer coax conductor is approximately equal to the thickness of the stripline substrate. It it is not (typically if coax is much larger than stripline substrate) a strong discontinuity might occure, so some other excitation based on planar transmission lines - transitions might work better.
flyhigh
The procedure depeds on your specific application. In general, the outer conductor is soldered to the ground plane, and the inner one is extended through a via an specific length (indirect coupling) or all the way to be soldered to the strip conductor (direct coupling). But the loacation of the contact point with strip in direct coupling or the length extension of inner conductor in indirect coupling and many other parameters influence the performance of your design and thus must be optimized accordingly.
If you be more specific about your problem, the disscusion can be more Concise and helpfull.
