how do run int main(int argc,char * argv[]) in the visual C++
hero0765
Member level 2
China
hi:
I want to run the below code in the the visual C++
#include<iostream>
#include<cstdlib>
#include<iomanip>
using namespace std;
cout << "argc = " <<argc <<endl;
for(int i =1; i<argc ;i++)
cout << "argv[" << i <<"] = "
<< argv << endl;
but the compiler run error:
: fatal error C1071: unexpected end of file found in comment
My project was built in the Win32 Console Application.
how can I disolve it ?
are you sure you posted the faulty code? I copied it into Visuall C++ and it compiles and runs OK.
Make sure to set your compiler to not use a precompiled header, or if you do, provide one (such as stdafx.h).
(If you use VC++6, do Project->Settings->C/C++ tab->select "Precompiled Headers" in the "Category" dropbox and select "Not using precompiled headers" radio button.)
Arthur
the compiler still can not be compiled without errors. I am using VC++ 6.0, any settings need to be made? I have made the settings provided by "arthur0" ,but the compiler have another error:
how can I do?
As horace1 pointed, I've also been able to compile your code without problems.
Are you sure you've given us the complete code? It sounds like you have a comment (i.e. "// some comment") on the last line of your file without a new line at the end...
If that's the case, make sure you go to the very end of the source file and press "Enter" to have an empty line at the end.
Just to be sure you have the right settings, copy the settings below and paste them (overwrite existing settings) in your Project->Settings->C/C++ tab->"Project Options" edit box.
/nologo /MLd /W3 /Gm /GX /ZI /Od /D "WIN32" /D "_DEBUG" /D "_CONSOLE" /D "_MBCS" /Fo"Debug/" /Fd"Debug/" /FD /GZ /c
hi:
thanks arthur0's help.
I have did as the same as you said, but the compiler still has errors :
LIBCD.lib(wincrt0.obj) : error LNK2001: unresolved external symbol _WinMain@16
Debug/CommandLineArgs.exe : fatal error LNK1120: 1 unresolved externals
Error executing link.exe.
CommandLineArgs.exe - 2 error(s), 0 warning(s)
what's wrong with my compiler?
---------- Post added at 04:03 ---------- Previous post was at 03:55 ----------
my project settings is as the same as the picture showed.
WinMain is the entry point in a Windows application. I thought you said you wanted a console application, but that’s obviously not what you’ve created (you chose the wrong wizard).
Anyway, the code you posted can only run as a console, so change the linker’s settings (in the ”Link” tab) to specify ”/subsystem:console” (instead of existing ”/subsystem:windows”).
Even better, copy the settings below and overwrite your linker’s (“Link” tab) project options:
kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib /nologo /subsystem:console /incremental:yes /pdb:"Debug/CommandLineArgs.pdb" /debug /machine:I386 /out:"Debug/CommandLineArgs.exe" /pdbtype:sept
Arthur
