How do i use Wi-Fi to control a set of relays?
t3symbol
Newbie level 1
I am doing a project on controlling 10 relays using wifi
I hv chosen a wifi module - Digi Wi-me module **broken link removed**
I want to interface my wifi module and a microcontroller using uart
then connect my relays to microcontroller
How do i go about
1. Building a web page to send signals via my wlan card on my system to the wifi module. what kind of programming language is best to use and sample programs i can get on web to serial communication?
2. I want my micro-controller to read my data from my module and turn off and on my relays. i need a sample code..?
I am totally new to micro controllers nd serial programming
Can some please help with details how to go about it?
Thanks
Well your kind of asking a lot for a forum but I will do the best I can. First off get yourself an Arduino Duemilanove-www.arduino.cc
Then get yourself a ethernet shield and wiznet module from www.adafruit.com(you can also buy the arduino their)
I am not sure how your device works but I was reading that you could interact with AOL's Instant Messenger using the ethernet shield.
The code should not be to difficult.
Most of the things in here should be correct but no promises.
It's a pretty difficult project if you need help drop me a line at spencerb8@yahoo.com
