Athina
rg213 model hfss
Hello.
Perhaps someone could help me, at least guide me into which tutorial to look at.. :/
I have designed a small patch antenna, with a resonance frequency of approximately 6.5Ghz. I cannot change its dimensions, since this is the largest antenna i am allowed to use in my application [it is a square 4cmx4cm antenna]. However, the antenna needs to have a resonace frequency around 3Ghz.
Thus, i need an adaptive circuit after the antenna (and before the rest of the electronics). The antenna is fed by a simple SMA for the time being. So, in order to model it in HFSS, i need to add a T. The one port is connected to the initial SMA, the second is where my feed is going to be, and in the third i should put an adjustable waveguide, followed by an open-circuit ( I think.. Am i correct in this???:?.
I have designed the T, but i have no clue on how to model the waveguide and/or the open-circuit.
Could anyone help me regarding the dielectric properties or the specific hfss components I should use?
Or even if there's an online manual about this, it will be really appreciated.
Thank you all in advance
Hello.
