binnyr
Junior Member level 3
- Joined
- Apr 26, 2002
- Messages
- 25
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 217
Hi:
I am working on a project which uses two boards build around Atmel AT90S8515. At present I am using RS232 to communicate between these two boards. In a longer run I would require to use RF to link these two boards.
I know there are ready-to-use RF Tranceivers modules that I can buy and use directly. (e.g check h--p://wxw.linxtechnologies.com/). However this will shoot up the cost of the solution (after the US$ to INR conversion).
Is these any way I can achieve two way RF communication between these two boards by some simple trick and low cost components?
Thanks and Regards
Binny
Thanks and Regards
Binny
