245VAC into the transformer and 34VDC leaving it
When I first checked for DC output 3 weeks ago I got the 50V reading which agrees with the 1.4 rule with no load. Today, its 245VAC to 34VAC to a 30VDC output with again nothing connected to the DC output. I'm confused. Is it defective?
I'm not sure what I'm going to do. Maybe I'll make the crowbar myself and use the old power supply.
I'm running the machines on a static phase changer
The transformer is tapped for 30VAC for a solenoid which switches the feed to the motor.
all of my machines were shipped ready for 240 vs 208
Of the four wires feeding the phase converter...
Can converters be run in parallel?
3S1 is a height cutoff switch (too high), 3S2 (too low).
3S3 is a push button for incremental raising of the table (up only)...very important.
3S4's are for manual up and down.
Shouldn't it have overvoltage protection?
OK, I guess I need something in between the DC out of the original supply and the motor. Any suggestions?
