how do i can solve for java object.....pls help..
wilfrid100
Newbie level 6
   public static Object[][] readTextFile()
    throws FileNotFoundException, IOException
  try
        BufferedReader in = new BufferedReader(
                new FileReader("C:/Documents and Settings/seng/Desktop/testfile/assignment_matrix.txt"));
        List list = new ArrayList();
        String text;
        while((text = in.readLine()) != null)
            Object[] out = text.split(" "); // Separated by "whitespace"
            for (int index = 0; index< out.length; index++)
                out[index] = Integer.parseInt((String)out[index]);  //problem here
            list.add(out);
        Object[][] output = (Object[][])list.toArray(new Object[0][0]);
        return output;
            catch ( IOException exc )
                exc.printStackTrace();
        return new Object[0][0];
does any1 can let me know how do i can solve for tis problem?
the complier say this is an
incompatible type, found: int, required: java.lang.Object
Integer.parseInt() returns int, which is a primary data type and cannot be casted to a reference data type. You can create an object of type Integer, which can be casted to Object. To do this, use the below statement
out[index] = new Integer(Integer.parseInt((String)out[index]));
