wee
Junior Member level 2
Hi all,
I would like to know more about the functionality of Equalizers? For example in a GSM Modulation and De-modulation stage.
The signal is modulated with GMSK scheme and demodulated at the receiver (assuming synchronized network) and then passed through a bandpass filter same as the transmitter end. Then the original signal is extracted (including some distortions). We will require the use of Equalizers to further improve the decoding using Max. Likelihood decoding technique.
I have chosen a good G but when i plotted the BER, the BER does not decline as Eb/No increases. I am not sure what went wrong.
Please advice.
Thank you.
Please advice.
Thank you.
