how coulud i know that the dual port ram have been built successfully?
the following step(quartus 5.0):
1。first tool->megawizard plug-in manager,then select "memory compiler",then select " ram-2-port",option is:
one read only port,one write only port;
the data width of the read port is 16 bit,and the data width of the address port is 12 bit;two port share one clock .
the data width of the read port is 8 bit,and the data width of the address port is 13 bit;
2。build a file named ram2port.vhd
3。the following is the code :
LIBRARY IEEE;
USE IEEE.Std_Logic_1164.ALL;
USE IEEE.Std_Logic_Unsigned.ALL;
USE IEEE.Std_Logic_Arith.ALL;
ENTITY ADSAMPLE IS
PORT
SysClk : in Std_Logic;
Led : out std_logic_vector(3 downto 0);
Rst : in std_logic;
END ADSAMPLE;
ARCHITECTURE Action OF ADSAMPLE IS
component ram2port IS
PORT
data : IN STD_LOGIC_VECTOR (15 DOWNTO 0);
wren : IN STD_LOGIC := '1';
wraddress : IN STD_LOGIC_VECTOR (11 DOWNTO 0);
rdaddress : IN STD_LOGIC_VECTOR (12 DOWNTO 0);
clock : IN STD_LOGIC;
q : OUT STD_LOGIC_VECTOR (7 DOWNTO 0)
--bulid an array named rambit_1[2048],an element 16 bit,
subtype ramWord_1 is std_logic_vector(15 downto 0);
type ramWordType_1 is array (0 to 11) of ramWord_1;
signal ram16bit_1 :ramWordType_1;
--build an array named rambit_1[4096],an element 8 bit,
subtype ramByte_1 is std_logic_vector(7 downto 0);
type ramByteType_1 is array (0 to 12) of ramByte_1;
signal ram8bit_1 :ramByteType_1;
u6:ram2port port map
data => ram16bit_1(dualPortRamWrAddrCount_1),
wren =>'1',
wraddress => conv_std_logic_vector(dualPortRamWrAddrCount_1,12),
rdaddress => conv_std_logic_vector(dualPortRamRdAddrCount_1,13),
clock => SysClk,
q => ram8bit_1(dualPortRamRdAddrCount_1)
END component;
the compile result is :
Total memory bits 0/230616 ?
why?
