How can we specify the pin of FET with VOM ?
khongai
Full Member level 4
hi all,
how can to specify the pin of FET with VOM ?
thank a lot
Re: FET ?
Those contacts which have less resistance are source and drain. They can be used interchangeably. Gate is the rest of the three. This method applies to those FET which are of depletion mode.
FET ?
Personally, I’d get the data sheet, post the fet part number and I’ll add a link
Bob
Re: FET ?
but i use voltmultimeter to specify the FET's pin and identify the FET live or die.
thank a lot.
Re: FET ?
the configuration is S D G frm the small hinge in the case
with a VOM you can use the low resistance between S and D to identify them
