Aug 17, 2005 #1 K khongai Full Member level 4 Joined May 20, 2005 Messages 229 Helped 16 Reputation 32 Reaction score 11 Trophy points 1,298 Activity points 2,919 hi all, how can to specify the pin of FET with VOM ? thank a lot
Aug 17, 2005 #2 N nvd Full Member level 2 Joined Jan 17, 2005 Messages 129 Helped 2 Reputation 4 Reaction score 2 Trophy points 1,298 Location Solar System Activity points 1,219 Re: FET ? Those contacts which have less resistance are source and drain. They can be used interchangeably. Gate is the rest of the three. This method applies to those FET which are of depletion mode.
Aug 19, 2005 #3 E Engineer_Bob Member level 1 Joined Jan 13, 2005 Messages 38 Helped 6 Reputation 12 Reaction score 0 Trophy points 1,286 Location UK Activity points 633 FET ? Personally, I’d get the data sheet, post the fet part number and I’ll add a link Bob
Aug 19, 2005 #4 K khongai Full Member level 4 Joined May 20, 2005 Messages 229 Helped 16 Reputation 32 Reaction score 11 Trophy points 1,298 Activity points 2,919 Re: FET ? but i use voltmultimeter to specify the FET's pin and identify the FET live or die. thank a lot.
Jan 8, 2006 #5 A A.Anand Srinivasan Advanced Member level 5 Joined Oct 15, 2005 Messages 1,792 Helped 257 Reputation 514 Reaction score 39 Trophy points 1,328 Location India Activity points 10,678 Re: FET ? the configuration is S D G frm the small hinge in the case with a VOM you can use the low resistance between S and D to identify them
Jan 15, 2006 #6 N neha_agarwal2k3 Junior Member level 2 Joined Oct 18, 2005 Messages 23 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,281 Activity points 1,490 Re: FET ? use voltmeter to specify pims
