How can I transmit this variable to USART ?
bianchi77
California
Guys,
Does anyone know how to transmit this variable ? I can transmit it already, but the character is not as expected...
num2str(ds1307_addr[2]));
I tried to use these functions to transmit :
void usart_transmit( unsigned char data )
	/* Wait for empty transmit buffer */
	while ( !( UCSR0A & (1<<UDRE0)) )
	/* Put data into buffer, sends the data */
	UDR0 = data;
void usart_pstr(unsigned char *s) {
	// loop through entire string
	while (*s) {
		usart_transmit(*s);
		s++;
any ideas ? thank you
What does num2str() does? Converts number to string? You have to send string to USART and not number. If num2str() converts number to string then you have to pass number as argument to the function. If it converts digit to character then you have to pass single digit.
Here's the function
// Implementing integer value from 00 to 99
char *num2str(char number)
	unsigned char digit;
	digit = '0';                       // Start with ASCII '0'
	while(number >= 10)                // Keep Looping for larger than 10
		digit++;                         // Increase ASCII character
		number -= 10;                    // Subtract number with 10
	sdigit[0]='0';                     // Default first Digit to '0'
	if (digit != '0')
	sdigit[0]=digit;                 // Put the Second digit
	sdigit[1]='0' + number;
	return sdigit;
usart_transmit(num2str(ds1307_addr[2])));
it's not displaying as I expected.....strange character...
Lets start with a value of 20 for number.
digit will be 0x30
In the first loop of while(number >= 10)
digit becomes 1 and number becomes 10
In the second loop digit becomes 2 and number becomes 0
loop is exited
sdigit[0] will be 0x30 = character '0'
Then comes
if (digit != '0')
sdigit[0]=digit;
This test passes as digit is 2, so
sdigit[0] becomes 0x02
sdigit[1] will be 0x30 + 0 = '0'
array is not terminated with null character so it is not a string.
so, you get 0x02,0x30 on terminal.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
void int2str(unsigned int number);
unsigned char convstr[20];
void int2str(unsigned int number){
    convstr[0] = number/10000 + 0x30;
    convstr[1] = (number/1000)%10 + 0x30;
    convstr[2] = (number/100)%10 + 0x30;
    convstr[3] = (number/10)%10 + 0x30;
    convstr[4] = (number/1)%10 + 0x30;
    convstr[5] = '\0';
void main(){
    //Pass convstr as argument to function which prints string on UART.
        usart_pstr(&convstr);
