how to make PCBs ?
Make the PCB design on the computer. Take the printout of the MIRROR image of PCB u have designed on the Press-n-peel sheet. Put the press-n-peel sheet on the the board and then hot iron (5 min approx) on the press-n-peel sheet. After that remove the press-n-peel sheet slowly. The print of your PCB will be transfered on the board. After that put your PCB in the ferric chloride solution (1 part of ferriccholoride in 3 parts of water) until all the copper is removed leaving the print of your PCB.
