How can I put "tick" sound ?
bianchi77
California
Guys,
I wanna create "tick" sound in between of second on my clock,
Here's the function :
/* initialise the PWM */
void pwm_init(void)
    /* use OC1A pin as output */
    DDRB = _BV(PB5);
    * clear OC1A on compare match
    * set OC1A at BOTTOM, non-inverting mode
    * Fast PWM, 8bit
   TCCR1A = _BV(COM1A1) | _BV(WGM10);
    * Fast PWM, 8bit
    * Prescaler: clk/1 = 8MHz
    * PWM frequency = 8MHz / (255 + 1) = 31.25kHz
  TCCR1B = _BV(WGM12) | _BV(CS10);
    /* set initial duty cycle to zero */
    //OCR1A = 0;
    sample_count = 4;
	sei();
beep_sound()
	 sample_count--;
	 if (sample_count == 0)
		 sample_count = 4;
		 OCR1A = pgm_read_byte(&pcm_samples[sample++]);
		 if(sample>pcm_length)sample=0;
display_time()
char tempCelcius[50];
char volts[50];
int  adc_result;
double adcA;
long adcresistance;
double d;
static unsigned char tenms=1;
	//beep
	beep_sound();
	tenms++;                  // Read DS1307 every 100 x 10ms = 1 sec
	if (tenms >= 100) {
		cli();                                // Disable Interupt
		// Read DS1307
		Read_DS1307();
ISR(TIMER0_OVF_vect)
  display_time();
 main()
// Initial ATMega128 Timer/Counter0 Peripheral
	TCCR0=(1<<CS02)|(1<<CS00);   // Use maximum prescaller: Clk/1024
	TIFR = (1<<TOV0);            //Clear pending TOV0 interrupt
	TCNT0=0x4E;                   // Start counter from 0x4E, overflow at 10 mSec
	TIMSK=(1<<TOIE0);            // Enable Counter Overflow Interrupt
	sei();
I can hear a sound already in the buzzer but it's not regular every second, sometimes it's on, sometimes it's off
Any ideas what do I miss here ?
Thanks
I'm not familiar with ATMega128 devices but it looks like you are using PWM to generate the tick sound. I suggest you try simply raising and lowering the output pin to pulse a current to the loudspeaker. If it needs a delay, I would suggest about 50mS.
Brian.
