I think the question is clear from the title
How can I programme a ''routing protocol in Ad-hoc networks'' I mean what is he best programmation language to do that ??
And If you have examples for that, it will be Okey
Up to my knowledge C is the best programming Language for protocol implementation under LINUX Platform..And please once check this link..for your reference http://www.olsr.org/docs/report.pdf
you can use network simulator-2 to simulate the moving node with various model of routing protocol like DSDV,AODV,OLSR, TORA, and many other.
check this link **broken link removed**
yeah brother
it's possible to use that
But I'd like to learn how can I program those protocols
what is the best, the easiest and the most developped programming language
How do you see the c# ??? and if you have some useful documents please help me
I decided using this one *ns-2* But I need to some documents about it
I'd like to learn it?? please, If you have some tutorials, that will be good for me
i use this tutorial for programming "nscript Version 1.0a USER’S MANUAL" by University of Virginia and "Introduction to Network Simulator NS2" by Elsevier and i implement ns-2 based windows platform using cygwin.
Please check this link Marc Greis' Tutorial for the UCB/LBNL/VINT Network Simulator "ns" for tutorial
Yah ..... you are using it ??? wonderful that means you'd help me if I had a problem
Because first at all I'll study it after that I'll start using it in my project
Please if you have some documents in French that will be better, But also in English it's good it's not a problem
