flatulent said:The usual way is to have two integrators in a loop. You need some nonlinearity in the feedback around each amp to limit the amplitude so that it is a sine wave and not a square wave.
semiconductor said:flatulent said:The usual way is to have two integrators in a loop. You need some nonlinearity in the feedback around each amp to limit the amplitude so that it is a sine wave and not a square wave.
Firstly, thank you
Secondly, Can you recommend me some websites that deal with this problem (for further understandings) or can you share some documents related to this problem?
Vitamin-C said:Hi,
I have a question for this kind of sinewave generator
using wien bridge:
How precise is this sine wave source ? Is it possible to
create a high SNR (> 80dB) source using this method?
Another question is whether a SNR>80dB sinewave could
be generated by sound card with dynamic range of +/-1V.
Please give me some idea
Vita
As i told, the Wien Bridge oscillator produce (ideally) an *absolutely* pure sine wave, whitout distorsion at all.
