avr_micro
Member level 3
Hi every body
I have a problem in Analog measurement?When i want to measure an analog sensor (For example output of LM35) by micro controller(For example AVR) i read that input in a loop every time so the value is very unbalanced and as you can see i this picture has some instantly changes and edges.I want to measure and show it soft(As second waveform in the same picture).How can i do this work?IS it possible by code in AVR or it should be done by external elements(Such as capacitors and ...) in circuit?
Here you can find picture.
https://tinypic.com/view.php?pic=6cdimqc
Regards
Regards
